How to add Suffix value to specific attribute value?
  • Nov 1, 2021 12:45 PM UTC
  • 202 views
Hi All,
I am working a project ,where client asked us to add suffix to a attribute value .This attribute value is not a Unique , in order to make it unique we have ad suffix values as shown below image , requesting you all to provide a solution ? to reach this requirement! (the suffix number should be 4 numbers)
imageThanks in advance.
Best answer by ebygomm
Use a counter, with a Counter Name/Group by set to the input Json document name, then an attributecreator/manager to add this attribute padded with zeroes to the document name
Forum|alt.badge.img+54
  • Nov 1, 2021 1:13 PM UTC
nielsgerrits
Forum|alt.badge.img+67
Multiple possibilities, this is how I do it:
  • Directory and File Pathnames Reader to scan for files
  • Excel Reader to read document with old and new names.
  • FeatureMerger to merge new names to files found.
  • AttributeCreater to create commandline command to rename file. (like this)
  • SystemCaller to run commandline.
geomancer
Forum|alt.badge.img+71
  • Nov 1, 2021 1:58 PM UTC
I removed my answer (using a ListBuilder and a ListExploder), as @ebygomm​'s solution is faster and uses fewer transformers.
  • Nov 1, 2021 2:33 PM UTC
Thank you ebgomm, it worked as per my requirement.
