How to add last modified date/time of Excel File and new Column in FME?
  • Oct 29, 2018 2:51 PM UTC
  • 231 views
Hi all,
I am wondering how is the best way to create a new column in fme with say last modified date and then extract the last time excel file was saved into the column for each record?
Thanks
Best answer by david_r
You can use Directory and File Pathnames reader, just remember to turn on the option to retrieve file properties.
Each feature will then have an attribute path_modified_date which probably contains what you're looking for.
gio
Forum|alt.badge.img+15
  • Oct 29, 2018 3:54 PM UTC
  • Oct 29, 2018 4:01 PM UTC
I have this information but can't see anything in FME to get the last date modifield.
  • Oct 29, 2018 4:26 PM UTC
  • Oct 29, 2018 4:37 PM UTC
That is super, thank you
