How to add an attribute in files exposed by File and Path directory transformer?
  • Nov 24, 2022 11:00 PM UTC
  • 10 replies
  • 317 views
smfks911
pathDirectoryissueDear Altruist, I have a consistent series of excel files but saved under different folder in respect to model_run no. Now I would like to add a column in each of the excel files as per the folder name that file is situated in. I have used 'Directory and File Path' transformer to expose all those excel file and used stringsearcher to create a column that extracted the folder name from the path. Can anyone please tell me how can I add the folder name as an attribute to the individual excel file?
regards/
danilo_fme
Forum|alt.badge.img+58
  • Nov 24, 2022 11:23 PM UTC
Hi @smfks911​
Please, could you share your Workspace?
Thanks in Advance,
Danilo
smfks911
  • Nov 24, 2022 11:26 PM UTC
Hi @smfks911​
Thanks in Advance,
Danilo
Hi @danilo_fme​ , here is my workspace.
Thanks.
caracadrian
Forum|alt.badge.img+23
  • Nov 25, 2022 6:34 AM UTC
If you want the new filename to be something like Run_0190_PP_BAU.xlsx you can just use an AttributeManager to set the value of path_filename to @Value(RunNo)_@Value(path_filename).
Concatenate attributes
smfks911
  • Nov 25, 2022 6:44 AM UTC
Hi @caracadrian​ Thanks mate but this is not the thing I am looking for. I am actually after adding a new column in each of those excel files that are exposed in path_filename.
caracadrian
  • Nov 25, 2022 6:47 AM UTC
Then send to FeatureReader, set Attribute and Geometry Handling -> Accumulation Mode to Merge Initiator and Result and send to an ExcelWriter
smfks911
  • Nov 25, 2022 10:09 AM UTC
hi @caracadrian​, in that case do you think I should path_dir_windows as the dataset or path_filename? can you see the attached?excelAccumulation
caracadrian
  • Nov 25, 2022 10:11 AM UTC
path_windows to read a file.
smfks911
  • Nov 25, 2022 10:56 AM UTC
Unfortunately, this is not returning what I am looking for. If you can afford time, I would like to have a one to one discussion with you. Thank you @caracadrian​
caracadrian
  • Nov 25, 2022 10:59 AM UTC
That sounds good.
We can do it tomorrow or on Monday. I'm on UTC+2 (EET). You can email me at carac.adrian@gmail.com
smfks911
  • Nov 25, 2022 11:08 AM UTC
Thank you so much. I have just shoot an email to you.
