How retrieve the cration date of Excel file (reader)
  • Apr 6, 2022 7:36 PM UTC
  • 294 views
I would like retrieve the date of a Excel file (in the reader). The date write in the Windows explorator.
I would like write this date in a field 'version' of my new file (in the writer)
Thanks a lot,
Best answer by dustin
You can use the Directory and File Pathnames Reader to read the file (with Retrieve file properties set to yes). The attribute you are looking for is path_created_date, which can then be copied to the field 'version'. You might also find the path_modified_date to get the latest date.
danilo_fme
Forum|alt.badge.img+58
  • Apr 6, 2022 8:11 PM UTC
Hi @tanmat​
The transformer DateTimeStamper can generate this information.
Thanks in Advance,
Danilo
dustin
Forum|alt.badge.img+36
  • Apr 6, 2022 8:19 PM UTC
  • Apr 7, 2022 2:01 AM UTC
Hi @tanmat​
Thanks in Advance,
Danilo
Hi Danilo,
Thanks for your answer, but I think that the transformer DateTimeStamper give only the date of the day when you run your workbench. But I don't think is it possible to retrieve with this transformer the date of the file.
  • Apr 7, 2022 2:07 AM UTC
Thanks a lot, I used the transformer 'FilePropertyExtractor' and then I retrieve the field '_file_mtime'.
It's exactly that I want, thanks
