How is attribute matching when converting IFC to OBJ
  • May 12, 2023 5:31 AM UTC
  • 124 views
When converting IFC to OBJ using FME, how does the information in IFC change to OBJ's attributes?
Best answer by itsmatt
So, can I know how FME converts IFC to OBJ?
It depends on who the converter is designed, however, the most simple would be to read the IFC File, and then just write it out to OBJ. There are a lot of different configuration options when reading ICF, If you choose to read everything then you will get allgeometries. FME will create internal FME geometries out of the IFC and then on the way out to OBJ it will do it's best to convert these geometries into OBJ mesh/lines geometries.
You can do a lot more in your conversion, for example you could output a single obj file for each ICF type. The filename could be based on the type name for example.
itsmatt
Forum|alt.badge.img+48
  • May 12, 2023 6:45 AM UTC
OBJ doesn't support attributes so it will all get lost unfortunately.
  • May 12, 2023 7:27 AM UTC
itsmatt
  • May 12, 2023 7:39 AM UTC
