Hello everybody,
My problem : I have a "Description" attribute which contains text with length variable. The lenght is greater than 2000 characters. For each feature of the "Description" attribute, I want to replace all spaces after every 80 characters with "LF" (new line).
So I thank use StringReplacer to write a regular expression to calculate 80 characters intervals and identify the space after each 80 characters. Then I could have replace this by LF.
I helped myself with these topics on the forum:
- https://knowledge.safe.com/questions/51531/how-do-i-find-the-first-space-after-the-19th-chara.html
- https://knowledge.safe.com/questions/51514/splitting-attributes-by-number-of-words.html
- https://knowledge.safe.com/questions/40715/count-the-number-of-characters-and-numbers-in-a-gi.html
But I d'ont success it. Maybe I don't really understand explanations....
Do you have any leads ?
Thank you so much !
You can use the TextWrapper custom transformer from the FME Hub, followed by a ListConcatenator to insert a LF between all the resulting list items.
Couldn't you just use Takashi's solution in the previous example, creating an attribute with the following:
@ReplaceRegEx(@Value(text),(.{80,}?)\\s,\\1
where text is the name of the attribute containing the original string?
Thank you david_r and jdh for your help ! I don't test your proposition jdb but I keep your idea !
dvid_r your solution do what I want perfectly ! Thank you !!
Thank you jdh for your help ! I don't test your proposition jdb but I keep your idea !
Funny, doesn't work for me. Rather than inserting newlines it seems to simply remove the space between the words every ~80 characters. Tested with FME 2020: regex_wordwrap.fmwt
Bad formatting on my part. Put the closing parenthesis on a new line
Devious regex... ;-)
