How do you create geometry from an array of coordinates?
  • Nov 15, 2022 4:25 PM UTC
  • 268 views
fme_hans
I have array with geometry type and coordinates. How can I easily make geometry out of it? I could make a wkt text with string replace but I suspect it could be easier.
The string with geometry type and coordinates is (shortened):
{"type":"MultiPolygon","coordinates":[[[[155469.406,463438.624],[155469.253,463444.217],[155467.196,463444.174],[155467.077,463444.172],[155462.4]4,408. [ 155469.406,463438.624]]]]}
  • Nov 15, 2022 4:32 PM UTC
Looks like GeoJSON, so I would first try the GeometryReplacer set to parse it as such.
fme_hans
  • Nov 16, 2022 7:27 AM UTC
It is indeed GeoJson. I had put a wrong attribute in the geometry replacer and that's why it didn't work. Now that I put the right attribute in the geometry replacer, geometry is created. Thanks.
