How do i store flat surfaces as object with geometry in IFC format
  • May 20, 2019 4:18 PM UTC
  • 100 views
trym
Participant
During my attempts to convert terrain made in FME (using the TINGenerator transformer) to IFC geometry, I have only managed to successfully store volumes. These are made by extruding flat surfaces to 3D extrusions. Then use the GeometryPropertySetter to set the Geometry Name to "Body". Then i store them with an Ifc writer named "IfcProxy". If I open this file with Solibri model viewer, it shows as a cube (screenshot 1).
However, i cannot seem to store a flat object using this method. (Screenshot 2)
Do you have any idea as of how to store flat geometry (instead of solid) using the IFC format writer?
daveatsafe
Forum|alt.badge.img+24
  • May 22, 2019 11:28 PM UTC
Hi @trym,
Most geometries in IFC are solids, with the exception of IfcSite. You should be able to write a TIN surface to IfcSite, with the geometry name 'Body'.
