How do I sort an attribute based on another attribute's order
  • May 30, 2019 7:51 PM UTC
  • 7 replies
  • 158 views
Column AColumn BB Sort AlphB Sort NumB Sort NatB Sort DesiredNYC51NYC1NYC1NYC11CHI1A11A11A1A51A5CHI511151111CHI5CHI11CHI1ANYC11NYCCHI
I'm trying to figure out how to sort column B to match column A's order. For my needs column B will not necessarily match column A but it will be a subset of column A
Best answer by takashi
I assume that you have two different source datasets - ColumnA and ColumnB, and need to sort the ColumnB features with the same criteria of the order of the ColumnA. If the assumption was correct, a possible way is:
  1. Add sequential number attribute (count) to the ColumnA features with a Counter.
  2. Add a FeatureMerger to the workspace. Send ColumnB features to the Requestor port, send ColumnA features to the Supplier port, in order to merge the count attribute from ColumnA feature to ColumnB feature having the same value as the ColumnA
  3. Sort the merged features by the count value.
  • May 30, 2019 10:11 PM UTC
Looks like a value in Column B is equal to a value in Column A. That is, the Column A seems to be your desired result. Why not just use the Column A?
  • May 31, 2019 12:22 PM UTC
Thank you for the response!
Sorry for the confusion, that was a poor attempt at an example. My actual columns don't match. All values in B would also be contained in A but B has duplicates that need to stay and is typically twice as large.
Actual Example:
ColumnA:NLBay,1,1A,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,KL Bay
ColumnB:3,2,32,5,36,KLBay,1A,1,23,NLBAY,20,4,22,39,28,10,27,10,29,24,14,2,34,38,4,7,26,12,16,26,14,11,30,38,1A,3,6,30,31,1,17,16,12,6,1A,8,25,35,38,NLBAY,3,1,18,29,15,33,19,35,1A,39,11,39,21,5,2,13,28,37,15,18,9,25,38,27,23,KLBAY,32,37,31,7,33,19,9,24,36,8,21,34,22,13,20,39,17,3,2,1
  • May 31, 2019 2:47 PM UTC
  • May 31, 2019 3:22 PM UTC
This should work:
Let a Sampler retrieve the first of each unique value of Column A and output the samples to a Counter. Let your source also directly enter a FeatureMerger as Requestor and let the Counter come in as Supplier. Output Merged and UnmergedRequestor to a Sorter that sorts Column B by _count. And you should be... eh, sorted.
  • May 31, 2019 4:39 PM UTC
This should work:
@takashi beat me to it. :-) Also note that my Sampler is unneccesary if your Column A only contains unique values, which I'm guessing it does. It might actually be unneccesary anyway, unless Column A has huge amounts of values.
  • May 31, 2019 5:16 PM UTC
That solution works flawlessly. Thank you Takashi!!
I still appreciate the feedback. Thank you very much for your help. It works perfectly
