How do I select only the attribute that contains user parameter.
  • Nov 24, 2020 8:19 PM UTC
  • 5 replies
  • 175 views
I have a google sheet with columns for Beg Date and End Date for several years (2019 Beg Date, 2020 Beg Date, etc). I have a user parameter for Year. I have a parameterFetcher to get the parameter but then how do I filter for only that year. If the user enters 2020 how do I only utilize 2020 Beg Date and 2020 End Date. Right now all of the years (2019 Beg Date …) show up as attributes.
  • Nov 25, 2020 3:40 PM UTC
You might be looking for a tester, as simple as it seems.
Just do a double test ( beginning_date =2020 Beg Date and end_date = 2020 End Date).
You just have to change the names so it fits.
If it is not it, could you please explain with more details ?
davtorgh
Forum|alt.badge.img+12
  • Nov 25, 2020 4:44 PM UTC
Hi @tsurveyor​ ,
I don't know if I understood right, but it seems you have a dataset with a number of columns potentially increasing to infinity, and it's not a good practice. Can you please provide an example?
  • Nov 25, 2020 6:03 PM UTC
I don't think Tester will work. I did find a work around but was looking for something more dynamic. The dates coming in from the reader:
FME_datesThere is a user parameter for month and year. So if I want to run the report from March 2019, I need to extract the 2019 Beg Date and 2019 End dates for March. I have a tester for the month - that's the easy part. How do I then extract just the 2019 dates? My work around is a TestFilter by year
FME_yearTestThen I have have an AttributeManager to remove the years I don't want and change the attribute name I want to just BegDate and EndDate so it's generic going forward.
FME_yearManagerThe selected dates then move on later to merge with my data and be filtered.
FME_dateFilterGeneral flow
FME_workbenchThis is a very manual way to do it that means adding to this list as time goes forward. Is there a more dynamic way to get only the dates I need?
davtorgh
  • Dec 2, 2020 11:22 PM UTC
Hi @tsurveyor​ ,
Basically the source schema is 'Closing Month' followed by one ore more pairs of '<year>_beg_date', '<year>_end_date'. Let me simplify the attribute names and call them
'closing_month', '<year>_beg', '<year>_end'.
The main idea is to use the names of the attributes '<year>_beg', '<year>_end' to restructure the data and obtain a four attribute schema: 'year', 'closing_month', 'beg', 'end' and then filter the resulting dataset against the input parameters.
We can proceed as follow:
  • create a '_fid' unique identifier for each table row (maybe it's not strictly necessary, but can help to clarify the flow) with a Counter;
  • explode the attributes with an AttributeExploder, so two new attributes are added '_attr_name' and '_attr_value';
  • filter out the unnecessary features (Tester) so to keep only the ones with begin and end dates (e.g. 2021_beg, 2021_end, 2020_beg, 2020_end and so on);
  • create three new attributes (AttributeCreator) 'year', 'beg' and 'end';
  • finally aggregate by 'year' and '_fid'.
Here is the the workspace
screenshot.1
...the output of the AttributeKeeper
screenshot.2
...the output of the Aggregator
screenshot.3
...and the final output with input month 'January' and year '2020'.
screenshot.4
It should work!
  • Dec 6, 2020 9:49 PM UTC
@davtorgh​  Thanks for that extensive explanation. I ended up deciding that the best solution was the simplest. I moved all of the calendar dates so it's one long list. My columns are now Closing_Month, Year, Beg_Date, and End_Date. So a simple test for month and year gets me the right dates. Not sure why I fought doing it this way in the first place since aesthetics are not relevant for this spreadsheet.
