How Do I select a string that only consits of a number.
  • Apr 20, 2018 2:11 PM UTC
  • 8 replies
  • 382 views
Hello,
I would like to replace the strings that only consists of number for example :11
Although I have string that are for example 11 xxx which should not be replaced.
In short, if the digit is followed by any word character Stringreplacer shouldn't select it but if the number is there buy itself then select it.
erik_jan
Forum|alt.badge.img+26
  • Apr 20, 2018 2:26 PM UTC
You could use the StringSearcher transformer with the regular expression: ^[0-9]*$
(meaning start then only digits then end).
  • Apr 20, 2018 2:28 PM UTC
Try the following in a StringReplacer:
^\d+$
It will only replace the attribute values that are entirely made up of one or several digits.
erik_jan
  • Apr 20, 2018 2:29 PM UTC
Or you could use the AttributeValidator transformer to test if the attribute is numeric.
Test for Type Numeric.
danilo_fme
Forum|alt.badge.img+58
  • Apr 20, 2018 2:30 PM UTC
Hi @oliwerurban,
I created a Workspace to test it. The transformer AttributeCreator was used to simulate 3 attributes: Solutial, Solutial11, 11.
After the transformer StringReplacer:
Thanks,
Danilo
Maybe consider using + rather than * to avoid matching empty values
gio
Forum|alt.badge.img+15
  • Apr 20, 2018 3:04 PM UTC
something wrong with this service?
This post is old, is it not?
  • Apr 20, 2018 3:18 PM UTC
It doesn't look very old to me, at least:
  • Apr 23, 2018 12:29 PM UTC
^\d+$
It works! Thank you very much
