How do I schedule an FMW script to run at regular intervals?
  • Sep 20, 2013 11:17 PM UTC
  • 58 views
sidneygis
Hello everybody,
I am a new-be to FME - can someone give me a step by step process on how to schdule an FMW script to run at a particular time and at particular intervals. For example,  9pm every second day.
I know when I run an FMW script, there's this at the beginning fo the log:
fme.exe WT-RoadSegment-AnnoToPolyAttrib.fmw
--SourceDataset_AUTOCAD_OD "\\\\data\\Sidney\\CorporateData\\Drawings\\AREA MAPS\\Town Maps\\RoadSegments.dwg"
--DestDataset_FILEGDB D:\\Fme\\Output-TEST\\WTRS.gdb
Where do I put this and how do I set up the time and interval. Thanks.
Jesse
GIS Technician / Town of Sidney
Best answer by fmelizard
Hi Jesse,
Via file > batch deploy you can create a batch (.bat) file of your ws.
this you can then schedule via your windows scheduler.
Hope this helps,
Itay
fmelizard
Forum|alt.badge.img+22
  • Sep 21, 2013 6:04 AM UTC
Hi Jesse,
Hope this helps,
Itay
