How do I Reorganize attributes AND use LineOnLineOverlayer at the same time?
  • May 11, 2017
  • 45 views
aron
Forum|alt.badge.img+16
I have a number of trails that are coded for different uses, e.g walking, skiing, horseback riding etc. I would like to find out where these overlap and at the same time create a rule set for the outgoing attributes. LineOnLineOverlayer seems to do the first, but it will only output one attribute so I cant do the attribute reorganizing afterwords. And I can not do the reorganizing before LineOnLine since I only want to sort the lines that actually overlap. Does anyone have a clever workaround for this?
I might ad some examples of the the attribute processing I want to do: A+B = (new attribute) G, A+C = A, B+D = B+D, and so on
itay
Forum|alt.badge.img+19
  • May 11, 2017
Have a look at the list result via the feature information window and not the table window in the Data Inspector.
jdh
Forum|alt.badge.img+41
  • May 11, 2017
In the LineOnLineOverlayer check the box to Generate List and fill in the parameters (name etc).
Then you can analyse the list to determine which attributes to combine/keep/
