I have DGN file. In Microstation I can see that it had a defined GCS (ETRS89 / UTM zone 32N) When I read the file with FME the coordinate system is not recognised. How do I get FME to read the GCS details?
How do I read the coordinate reference system in a DGN file?
Best answer by jovitaatsafe
Hi @eric_armitage,
Unfortunately it looks like our Microstation reader/writer format does not currently have support for coordinate systems according to our format documentation. We have an enhancement request tracked internally as (FMEENGINE-9051) to add support for coordinate systems. I've linked this question to it and we'll be back to update when it's been addressed.
For most other formats that do support coordinate systems though, it is definitely possible to set it in the reader or CoordinateSystemSetter if you know the corresponding coordinate system for the dataset.
