How do I perform a spatial join that merges attributes based on the area of overlap?
  • Aug 21, 2019 4:18 PM UTC
  • 5 replies
  • 846 views
I have two polygons, one of parcels and one of building footprints. I am trying to merge the attributes of the parcels to the buildings. A Spatial Relator or Filter would be the obvious answer, but some of the building footprints overlap more than one parcel. I want to merge the attributes of the parcel the building is found MOSTLY within. In the case of the below picture, the red building is adopting the parcel attributes of #2. Is there a way I can prioritize the amount of overlap determining which attributes are joined, therefore adopting parcel 1?
erik_jan
Forum|alt.badge.img+26
  • Aug 21, 2019 4:59 PM UTC
Have a look at the AreaonAreaOverlayer transformer.
That is built for cases like this.
arnovananrooij
Forum|alt.badge.img+5
You might want to try the MaxOverlappingFeatureMerger transformer from the FME hub.
brian_
Forum|alt.badge.img+4
  • Aug 21, 2019 11:48 PM UTC
Another way to do a max area based spatial join is to use a clipper>sort it by descending area>filter the duplicates. So,
1. Clipper (Merge Attributes) - Clipper: red polygon building
2. AreaCalculator (from Inside port)
3. Sorter - _area by Numeric, Descending
4 DuplicateFilter - by unique id of building
So from the Unique port you should have the parcel (by largest area) attributes attached
  • Aug 22, 2019 12:07 AM UTC
Good suggestion. In addition, if you need to preserve the original geometry of the building, you can use a pair of GeometryExtractor (before Clipper) and GeometryReplacer (after DuplicateFilter) to save and restore the geometry.
  • Aug 22, 2019 3:50 PM UTC
Thanks, this accomplished what I needed
