How do I multiply some string attribute values based on another number value ?
I need something like 3*bottle = bottle;bottle;bollte.
First table is what I have and second what I need.
Unbenannt
Best answer by danilo_fme
danilo_fme wrote:
Workspace_Agg_
Result:
Result_agg
Workspace attached.
Thanks @gisgis​ for your reply.
I inserted the transformer counter before to create a ID for each line.
Attached the Workspace.
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+45
  • July 19, 2022
Hi @gisgis​
I suggest you to use the transformer Cloner.
In the number of copies, you can select the attribute that you have.
After, you can use the transformer aggregator.
Thanks in Advance,
Danilo
danilo_fme
  • July 19, 2022
danilo_fme wrote:
Hi @gisgis​
Thanks in Advance,
Danilo
Workspace_Agg_
Result:
Result_agg
Workspace attached.
  • July 20, 2022
danilo_fme wrote:
Workspace_Agg_
Result:
Result_agg
Workspace attached.
thanks a lot but there is one small thing, what if I have some more lines with the same value which of course I dont want to group ? I need the same number of output lines as input. I updated my table
2
danilo_fme
  • July 20, 2022
danilo_fme wrote:
Workspace_Agg_
Result:
Result_agg
Workspace attached.
Thanks in Advance,
Danilo
