How do I get these JSON field extract in FME 2016
  • Nov 2, 2017 7:06 PM UTC
  • 66 views
dbklingdom
Forum|alt.badge.img+7
I have HTTPCaller connect to JSONFragmenter connected to JSONExtractor. Are these list that have to be converted?
erik_jan
Forum|alt.badge.img+26
  • Nov 2, 2017 7:09 PM UTC
I believe the ListExploder is what you are looking for.
  • Nov 3, 2017 12:26 AM UTC
I think that the best way depends on the structure of the source JSON document and what your goal is. For example, if the JSON document was:
    "result" : [
        {"A" : 1, "B" : "foo"},
        {"A" : 2, "B" : "bar"}
The JSONFragmenter with this setting outputs two features - the first one has two attributes A = 1, B = "foo", and the second one has A = 2, B = "bar".
  • JSON Query: json["result"][*]
  • Flatten Query Result into Attributes: Yes
I guess basic structure of your JSON document is similar to the example above.
dbklingdom
  • Nov 7, 2017 8:34 PM UTC
Hey, thanks for the reply. listExploder worked great in 2017, 2016 is another thing.
