How do I get the Eula Angles of a line in a Polygon?
  • Mar 22, 2022 4:32 PM UTC
  • 36 views
I have a polygon and I want to know the angle α  , β  , γ of each line.With the PointPropertyExtractor I get the Eula Angle if I set it beforehand with the PointPropertySetter and then rotate the object.
Is there a possibility to find the angular inclination of the line to α , β , γ differently? PolylineAnalyzer, HorizontalAngle and TopologyBuilder have not helped me so far.Screen Shot 03-22-22 at 05.29 PM
danminneyatsaf
Forum|alt.badge.img+13
Hi @mariok​ what format is your 3D data in? Some sample data would also be useful as it may help myself or others to better answer your question. You may also find some direction by referencing this other post on the FME Community asking a similar question.
Kind Regards,
Dan M
