How do I get Intersector to output source attributes through the Node port?
  • Mar 10, 2016 4:08 PM UTC
  • 31 views
Hi
I am currently trying to add a Node whereever there is an intersection between a polygon and a line. I am using 'Intersector' for this and it appears to be doing what I want it to.
My issue is that I need to bring the ID on the source line feature onto the nodes that come from the Node port. At the moment, I am only getting the following attributes:
_node_num,
_overlaps,
_segments
Can anyone help please?
Many thanks in advance.
Regards
Graham
erik_jan
Forum|alt.badge.img+26
  • Mar 10, 2016 6:06 PM UTC
As the node can have attributes from different lines you need to use the List Name setting to generate a list of attributes from all source lines that are coming together in the node.
You could follow up with a ListExploder to generate multiple points with attributes for each entry in the list (and could eliminate duplicate entries by using the ListDuplicateRemover first).
  • Mar 11, 2016 11:03 AM UTC
Hi @eric_jan
You're an absolute star!
Thank you so much it worked a treat.
Kind regards
Graham
