How do i create lines from a point file based on two attributes in the point table
  • Nov 5, 2019 4:04 PM UTC
  • 37 views
So i have a vessel dataset of points that has a position time and mmsi field that i want to create a line for each mmsi using the time field.
  • Nov 5, 2019 4:14 PM UTC
Hi @anthonyg, you can use the LineBuilder (Group By: mmsi) to create lines for each mmsi. If the input features aren't ordered by time, consider using the Sorter to sort them by time beforehand.
