How do I count the number of features and included in file name
  • Aug 8, 2019 10:17 AM UTC
  • 98 views
I'm completing a government return which will need to be sent daily and they require the file to be named as below:
File naming:
CAZ-yyyy-mm-dd-XXXX-#.csv
where:
yyyy-mm-dd represents the date the file was generated
XXXX is the agreed identifier for each Licensing Authority (to be confirmed)
# is the total number of records included in the file.
The date is easy enough to solve, but I'm hitting a brick wall trying to insert the feature count into the file path. So far I've got:
CAZ-@DateTimeFormat(@DateTimeNow(),%Y-%m-%d)-XXXX-#
Could anyone help with the #?
Best answer by ebygomm
You can use a Statistics Calculator to count the number of features - the total will be added to all features coming out the complete port and you can then this as part of your fanout
e.g. CAZ-@DateTimeFormat(@DateTimeNow(),%Y-%m-%d)-XXXX-@Value(total_count)
Forum|alt.badge.img+54
  • Aug 8, 2019 10:28 AM UTC
  • Aug 8, 2019 10:31 AM UTC
Thanks but, I don't want the file to fanout, just a single file with the total features in the filename
  • Aug 8, 2019 10:35 AM UTC
It won't actually fanout, because all the features will have the same value
  • Aug 8, 2019 10:39 AM UTC
Ah I see, that worked nicely!
Thanks!
