How could i add a point at end of line ,has no more intersecting with any lines or any areas
  • April 15, 2020
  • 18 views
gogopotter90
Forum|alt.badge.img+13
i would like to Add a point to end node of Lines that has no more connection with any lines or any area .
i have read ,that i have to use vertex creator ,Add point but iam not sure how it works
i have used aggregator group by network_id , so i have many lines connecting together ,depend on the network .
i would like to add a node at end of each network when the network has no lines connecting from any side ,so i want to add the point , but if there is connection between lines and another lines so i do not need to add a point .
somelines have already node at the end without any connection lines but some not ,my target the line that has no node at end ,i want to add a point
Thanks in advance for any help .
Best answer by markatsafe
@gogopotter90 Use TopologyBuilder to create a network with Nodes. Then use SpatailRelator or PointOnLineOverlayer to match the points & lines. Create a list for the points. the points that have only one list element will be the points with no other connections.
  • April 15, 2020
