How come JSON null values are handled differently by different transformers?
  • November 28, 2021
  • 85 views
thijsknapen
Forum|alt.badge.img+10
Hi folks,
While working with some JSON data, I seem to have noticed that null values are sometimes interpreted as a literal string, instead of a true <null> value (like non-existent/empty).
When I just tried to replicate this, it seems that different FME JSON transformers seem to handle null values in a different manner. E.g. when using a JSONFragmenter or a JSONFlattener, it seems that null values are indeed recognized as true <null> values (like non-existent/empty), but when using a JSONExtractor or an XMLXQueryExtractor (with a JSONiq query), it seems that null values are returned as a literal string.
Of course in the latter case I could add a NullAttributeMapper transformer to change the literal string 'null' to the <null> value, but this seems like a bit of a workaround (and also, how would you then distinguish between a literal string value "null" in JSON, and the true null value)
Is there something I'm missing, or is this a bit of a bug?
Kind regards,
Thijs
ps. see the below screenshot for an illustration of the case, and/or the attached workspace.
hasant1973
Forum|alt.badge.img+3
  • June 16, 2023
I have the same problem.
city : null
is not the same as
city : "null"
But JSONExtractor returns "null" and I need to check for it with another transformer and make <null> out of it. That's actually a BUG.
