Hi there,
I'm exporting rvz files to a esri file geodatabase. When I want to open the multipatches in ArcGIS pro I have to adjust the elevation to make the features visible. In Revit it is possible to built storey /levels and give them a height or elevation value. How can I transfer Z-values to arcGIS and use them as an attribute field for the elevation source?
Thank you. I hope my question makes sense.
