How can I test if an attribute value is of type INTEGER regardless which size?
  • Nov 7, 2017 4:14 PM UTC
  • 5 replies
  • 465 views
kalbert
Forum|alt.badge.img+14
The TESTER transformer let pass only 32bit INTs when using 'type is' Integer as operand. I need to test if the value is 64bit Integer or smaller (but no double or float).
I used also AttributeValidator with the same result.
Best answer by erik_jan
You can use the test in the Tester:
Attr1 = floor(Att1) as in the image.
erik_jan
Forum|alt.badge.img+26
  • Nov 7, 2017 5:05 PM UTC
  • Nov 7, 2017 5:14 PM UTC
I can confirm that using FME 2017.1 and the AttributeValidator to check for "Is Type Integer" is equivalent to checking if the attribute is a signed 32-bit integer, i.e. in the range -2,147,483,648 to 2,147,483,647.
Anything outside that range will fail.
The tip from @erik_jan is a good workaround.
mark2atsafe
Forum|alt.badge.img+59
I filed this with the developers as PR#80373, so hopefully we'll get this improved upon.
kalbert
  • Nov 8, 2017 8:18 AM UTC
@erik_jan
Many thanks, a great solution. Teaches me that it's worth looking closer at all the math functions (e.g. @uint64(@value(Att1)) works as well).
mark2atsafe
I'm told this is fixed in FME2018, although I don't know the specific build number.
