How can I spool SQL query log to a file using SQLExecutor?
  • October 19, 2016
  • 6 replies
  • 75 views
jan
jan
  • October 19, 2016
example of how I'd like to spool an sql statment to a file:
spool "C:\\Users\\test.txt"
  • October 19, 2016
You could construct the SQL to execute in an attribute (or a private parameter) and send the query to the Logger before the SQLExecutor.
  • October 20, 2016
Agreed. The AttributeFileWriter might also be an option if you want to write the SQL statement only. e.g.
jan
  • October 20, 2016
I don't quite get this! It does not log the result of the query ?
  • October 20, 2016
What do you want to log, the query or the results?
  • October 20, 2016
Naturally it will not save the result from the query. It just saves the SQL statement into a file.
Perhaps did you mean the Oracle SPOOL command? If so, unfortunately it seems that there is no way to execute the command with the SQLExecutor. Consider using the CSV writer, if you want to save the query result into a text file.
