How can I set an attribute to a list value within a PythonCaller?
  • Feb 18, 2022 8:11 PM UTC
  • 6 replies
  • 1174 views
lukehicks
I am having issues setting an attribute within a python caller.
I am reading in a list of strings, mutating the components in the list, then trying to overwrite the same list. Currently, the results of the output are the same as the input.
Below is an example of how I am doing it.
x = feature.getAttribute(list{}.item)
for i in len(x):
     <mutate items in list>
feature.setAttribute("list{}.item", x)
Can anyone let me know why this is not working, and how I can fix this? Thank you.
hkingsbury
Forum|alt.badge.img+73
  • Feb 20, 2022 7:38 PM UTC
def processFeature(feature):
    x = feature.getAttribute('_list{}.item')
    for i in range(0,len(x)):
        _i = str(i)
        val = feature.getAttribute('_list{'+_i+'}.item')
        y = str(val)+'__'
        feature.setAttribute('_list{'+_i+'}.item',y)
The above will append '__' to the end of each item in the list.
A couple of things to note with your code, len(x) returns an int, ints aren't iterable, by placing it in range() we get a list which can be iterated over
You need to indiviually update each item in the list using setAttribute()
lukehicks
  • Feb 22, 2022 2:47 PM UTC
        _i = str(i)
        y = str(val)+'__'
Sorry, the len(x) was an oversight in my example writing.
Does this work if the output list is shorter than the current list? For example if I am using x.pop(_i) for some values, the items at the end of the list may be missed.
Forum|alt.badge.img+54
  • Feb 22, 2022 3:04 PM UTC
You can use this syntax to set the list, you don't necessarily need to iterate
But are you actually changing x in your code, before you use it to set the list attribute, e.g.
    x = feature.getAttribute('list{}.startIndex')
    x = [str(i)+"_test" for i in x]
    feature.setAttribute('list{}.startIndex', x)
hkingsbury
  • Feb 22, 2022 8:18 PM UTC
in that case you could do something like this (exclude when list val = 2).
if your input is ["1","2","3","4","5"], your output will be ["1__","3__","4__","5__"]
import fme
import fmeobjects
    new = []
        _i = str(i)
        if val == 2:
            pass
        else:
            y = str(val)+'__'
            new.append(y)
    feature.setAttribute('_newList{}.item',new)
hkingsbury
  • Feb 22, 2022 8:22 PM UTC
Yea, you can also iterate over the list natively, in this case it is better to do your (@ebygomm​ ) approach (went the range()/len() approach as @lukehicks​ initial code include the len() of the input list)
  • Feb 23, 2022 12:42 AM UTC
For what it's worth, I prefer to use the enumerate function when iteration with for statement is required.
Example: Assign value of "_list{N}.item" to new attribute "_item_N"
        items = feature.getAttribute('_list{}.item')
        for i, v in enumerate(items):
            feature.setAttribute('_item_%d' % i, v)
