How can I programmatically download a backup from FME Server?
  • Jan 23, 2017 11:04 PM UTC
  • 102 views
fmelizard
Forum|alt.badge.img+22
Best answer by fmelizard
Here is a workspace that uses the REST API to download a backup from FME Server
backup.fmw
fmelizard
  • Jan 23, 2017 11:08 PM UTC
You can use the REST API call: /migration/commands/backup/download
https://docs.safe.com/fme/html/FME_REST/v2/apidoc/index.html#!/migration/syncBackup_post_0
Here are the settings to use in Postman:
fmelizard
  • Jan 23, 2017 11:31 PM UTC
backup.fmw
fmelizard
  • Jan 25, 2017 12:39 AM UTC
Here is a cURL command that I exported from Postman:
curl -X POST -H "Content-Type: application/x-www-form-urlencoded" -H "Accept: application/octet-stream" -H "Cache-Control: no-cache" -H "Postman-Token: b0e3b38b-8f9c-0900-8b51-5a4854e7cfc9" -d '' "http://ap-fme32bit/fmerest/v2/migration/commands/backup/download?accept=contents&token;=45228cf4eae10fc585917c61d7bf2be721783878&exportPackageName;=ServerConfigPackage.fsconfig"
Note: I haven't tested it in cURL.
itay
Forum|alt.badge.img+19
  • Jan 25, 2017 10:14 AM UTC
And if you just want to save the backup file in the resources area:
/migration/commands/backup/resource
