How can I make relation among smallworld circuits in FME
  • Dec 11, 2018 10:36 AM UTC
  • 50 views
esaka
Participant
Hi everyone,
I have a good question that I tried to achieved but this is very difficult for me.
I have circuits in the smallworld database. This circuits have got a simple parent-child relationship. There are many circuits like this but there is no relation first circuit with 3th circuit. If I accept the first circuit is a parent, this parent related downstream circuit mean that its own child circuit. However this parent circuit doesn't have relation with its own child's downstream circuits.
I would like to make a relation among from first circuit to end....
I have got circuit_line as shape format and the related internal table as excel in the attached
You can consider and start from this parent id 46598749 circuit id =5018-OG-6002
Your browser does not support HTML5 video.
erik_jan
Forum|alt.badge.img+26
  • Dec 11, 2018 2:25 PM UTC
Could you use the PathBuilder (and generate a list from circuits it finds) or the ShortestPathFinder transformers?
Not sure, but we usually use Magik code in Smallworld for this kind of calculations.
esaka
Participant
  • Participant
  • Dec 12, 2018 6:44 AM UTC
Thanks for suggestion @erik_jan.
Actually I tried to go with geometric approach but I realized that the Smallworld internal tables already keep the relation. I would like to use this internal tables and make a tree model like below image. All the circuits are connected as parent-child to the end.. By the way I replicated the smallworld database to postgis. what I want to do I will do in postgis. I am not sure, can I make a relationship without spatial functions.
