How can I insert a block with (autocad) attributes and fill in the values?
  • Mar 30, 2020 11:33 AM UTC
  • 203 views
sprongandre
I have a block which contains (Autocad)attributes, in Autocad you can edit them by double clicking on it.
I would like to insert this block in a dwg and fill in some values.
When I put this block in a template and insert it with the dwgstyler than it becomes a default block, whithout the 'doubleclick' functionality.
How can I insert a block with (Autocad)attributes and fill in the values?
Thanks!
daveatsafe
Forum|alt.badge.img+24
  • Mar 30, 2020 6:25 PM UTC
Hi @sprongandre,
I tried a quick block placement using the DWGStyler, and double-clicking the resulting block did bring up an attribute editor. Would you mind sharing your workspace, so I can test it?
sprongandre
Hi @sprongandre,
Hi @daveatsafe, I don't know what I did wrong yesterday but now it works :-)
