How can I get the TesseractCaller to output to the Line port rather than the Text or Reject ports?
  • Oct 9, 2018 9:58 PM UTC
  • 141 views
I have downloaded the tesseractcaller and tesseract but when I run a workspace I can not get any output on the Line port. When I use the output type of Text the output is returned in the Text port. But when I choose hOCR a "Tesseract didn't find any text on this raster" error is returned on the Rejected port. I get this result on the TesseractTest.fmwt example as well as the other samples provided by Safe Soft. Let me know if I have missed a setting somewhere.
jovitaatsafe
Forum|alt.badge.img+11
Hi @fdharris13,
Sorry to hear that you're having some trouble with the TesseractCaller. We have a known issue that is in the works at the moment. The workaround that a colleague of mine found, is to go into the TesseractCaller custom transformer tab, and locate AttributeCreator4 (you can do this quickly in the navigator under Transformers). Change the _extension parameter under Attribute Value of Else to hocr. Then try running the workspace. This should do the trick for the example workspaces.
The second thing to check is what version of Tesseract you have. I have been able to test successfully with the older stable version (3.05.02). Consider installing the current stable version as opposed to the beta if you have edited the parameter and the transformer still isn't working for you. You can install that here.
The last thing to check is to make sure that the file path in the TesseractCaller points to your tesseract.exe file.
  • Oct 10, 2018 4:12 PM UTC
Hi @fdharris13,
Changing the attribute value solved my problem. Thanks for your help!!
