how can i get only the intersected lines with polygon and delete the rest of lines inside the polygon by clipper
  • Feb 26, 2020 10:06 AM UTC
  • 73 views
gogopotter90
Forum|alt.badge.img+14
could i ask how to get in inspector only the lines that intersected with polygon ,
i tried alot with clipper
polygon as input for clipper and lines input for clippee
output from inside ,i got the intersected lines with polygon plus all lines inside the polygon .i want only to have the intersected lines with polygon and delete the rest of lines inside the polygon
how could also give intersected lines specific colour .
Thanks alot
Forum|alt.badge.img+63
Try the SpatialFilter instead of the Clipper.
arnold_bijlsma
Forum|alt.badge.img+16
First, use a GeometryCoercer to change your polygon to just its perimeter line, so you don't get the lines that are fully inside your polygon. Then, as @redgeographics says, use a SpatialFilter (or SpatialRelator or LineOnLineOverlayer).
gogopotter90
  • Feb 26, 2020 11:46 AM UTC
thanks for reply it is working great nw
gogopotter90
  • Feb 26, 2020 6:06 PM UTC
thanks alot
