How can I fan out to individual features in a GDB based on the "LAYER" attribute found in my data?
  • Oct 19, 2022 3:49 PM UTC
  • 5 replies
  • 333 views
I realize the fanout option is probably the best option. I have not used FME in quite a while and am looking for someone to spoon feed this to me.
I need to read in a single GDB and export to another GDB based on the "LAYER" field.
dustin
Forum|alt.badge.img+36
  • Oct 19, 2022 4:05 PM UTC
The fanout option would be used to create multiple gdbs named per the LAYER field. To create feature classes based on the LAYER field: In your writer parameters, set the Feature Class or Table Name parameter to 'LAYER'.image
  • Oct 19, 2022 4:20 PM UTC
So I do this and I get the error: Geodatabase Writer: Feature Type Definition 'Traffic Separation Scheme Boundary' was requested, but not defined
  • Oct 19, 2022 5:05 PM UTC
To me, it is reading in the "feature_type" which in this case is "Traffic Separation Scheme Boundary" and trying to Write based on "LAYER" which has a different value then "Traffic Separation Scheme Boundary". Can I force my reader to read in features based on "LAYER"?
  • Oct 19, 2022 6:30 PM UTC
I want to read in everything from the GDB, dynamically I believe, I dont want 600 separate feature class readers coming in, then I want to fanout my current feature classes based on the "LAYER" field. When I attempt this I get that error. This seems extremely easy and I am probably missing one or 2 clicks/settings.
@sjolster31​ FME is trying to create a layer called "Traffic Separation Scheme Boundary" but there is no schema to tell it what to create. You need to link the "Traffic Separation Scheme Boundary" to the source feature - probably using fme_feature_type. The Dynamic Workflows tutorial describes some of this. Probably in the section Destination Schema Contains Different Feature Type
