How can i extract polygons from one feature class for each intersection it has with many different polygons from another feature class?
  • May 11, 2018 6:21 PM UTC
  • 121 views
I have been running spatialfilter transformers on polygons from a grid feature class (G) to see which of them intersect polygons from another feature class (A). I am extracting the polygons from G that intersect A and applying the attributes from intersecting A polygons to their corresponding G polygons. Unfortunately some polygons from A intersect other, different polygons from A and the problem is I need to extract the G polygons for each intersection that is found between A and G. Essentially I need to extract duplicate G polygons for each intersection with different polygons from A and apply attributes from A to their corresponding duplicate. I really hope I was clear enough for someone out there to understand my issue. Thank you for your help in advance.
Best answer by daveatsafe
Hi @krenty,
I think the SpatialRelator transformer can help you. It can create a list of the attributes of all the A polygons overlapping any G polygon, and add that list to the G polygons.
daveatsafe
Forum|alt.badge.img+24
  • May 11, 2018 8:11 PM UTC
Hi @krenty,
fmelizard
Forum|alt.badge.img+22
  • May 11, 2018 8:51 PM UTC
Hi @krenty,
Then next step is to 'explode' the list with a 'List Exploder' - be sure you are creating a list in the Spatial Relator
