How can I extract groups of 50 rows and create N polygons with attributes from a text file?
  • January 14, 2020
  • 22 views
The output feature class based on the sample data should have 3 features (one per file) and 50 columns named and populated from all lines which include the symbol “=”, e.g line 7: LIDAR POINT COUNT=35,391,512, where the ColumnName is "LIDAR POINT COUNT" and the Value is "35,391,512".
The polygon should be created using the UPPER LEFT X, UPPER LEFT Y, LOWER RIGHT X and LOWER RIGHT Y.
The number of features will vary from file to file; another file might result in 312 features.
I have managed to extract the desired rows and aggregate them into the requisite 3 features (see attached 2017 fmw), but am now stuck as to how to pull the attributes back apart and build the polygons...
Best answer by cdalessandro
One way to doso was to create and reread a csv temp file. i wrote a workspace for You. This shold be the result You were looking for.
group_counter.zip
cdalessandro
Forum|alt.badge.img+4
  • January 14, 2020
group_counter.zip
  • January 14, 2020
@cdalessandro Thanks!
