How can I determine if the value in a column is the same for all rows
  • Oct 14, 2025 12:09 PM UTC
  • 128 views
plynn
Forum|alt.badge.img+10
I have a transformer that pulls data and returns something like this:
All values in the _count column should be the same.  How would I go about determining if there is more than one unique value?
Best answer by ebygomm
The Statistics Calculator has a Value Count option which will count the number of values. Just check the calculation method (string v numeric) and be aware that this won’t count nulls or missing, i.e. if you have 3 records with a _count of 9 and one where _count is null the value_count result will be 1
s.jager
Forum|alt.badge.img+27
  • Oct 14, 2025 12:15 PM UTC
The simplest way would be to use a Tester (_count=9). Unless your _count can have other values, in which case you can use several options. Calculate the statistics for example, or use the AttributeManager with adjacent feature checking enabled, or even a DuplicateFilter. I think I would use the  StatisticsCalculator.
plynn
  • Oct 14, 2025 12:22 PM UTC
Yes, unfortunately the _count value will change.  If I use the StatisticsCalculator, would I then just put a Tester transformer after it to check if the summary output is > 1?
Forum|alt.badge.img+54
  • Oct 14, 2025 2:18 PM UTC
