How can I create an empty new folder with a prefix_ followed by current date time?
  • Nov 14, 2023 4:54 PM UTC
  • 238 views
Hello,
I am trying to create a folder with a prefix of Run_ and have the current datetime as the folder name. I am very new to FME and I am not sure what I am doing wrong with the setup that nothings gets created in the path I have as destination (screenshot below). I appreciate any help.
dustin
Forum|alt.badge.img+36
  • Nov 14, 2023 5:36 PM UTC
What is your input for the writer? If you don't have any features to feed into it currently, you can use the Creator transformer to create a feature. Also, you may want to read into the format attributes of the writer...filecopy_source_dataset and filecopy_dest_filename.
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/filecopy/filecopy.htm
Alternatively, I usually use either a PythonCreator or PythonCaller when I need to create directories. The below code in a PythonCreator will create the Run_ folder, you will just need to update the dir variable to where you want the folder to be created. You can also link the dir to a published parameter in the code.
import fmeobjects
import os
from datetime import datetime
class FeatureCreator(object):
    """Template Class Interface:
    When using this class, make sure its name is set as the value of the 'Class
    to Process Features' transformer parameter.
    def __init__(self):
        """Base constructor for class members."""
        dir = "E:\\your_path"
        new_dir = os.path.join(dir,"Run_"+datetime.now().strftime("%Y%m%d"))
        if not os.path.exists(new_dir):
            os.makedirs(new_dir)
        pass
    def input(self, feature):
        """This method is called once by FME to create FME Feature(s).
        A created Feature is emitted through the self.pyoutput() method.
        Any number of Features can be created and emitted by this method.
        :param fmeobjects.FMEFeature feature: Dummy FME Feature passed in by
            FME. It can be ignored.
        newFeature = fmeobjects.FMEFeature()
        self.pyoutput(newFeature)
    def close(self):
        """This method is called at the end of the class."""
        pass
