How can I clone a polygon based on multiple spatial (point) intersects?
  • Sep 12, 2016 4:42 PM UTC
  • 86 views
I have a case where a polygon is overlapped by several points stacked on top of a polygon (kind of like coins stacked on top of a coaster).
I would like to clone the polygon so that the attributes of each point are merged to the corresponding overlapping polygon. In the end I have 1 polygon for each point, e.g.,
Before:
1 coaster, three overlapping coins:
Coaster ID1
Overlap Coin IDsYearValue12009.2522010.0531957.01
After:
3 coasters, one for each overlapping coin.
Coaster IDsYearValue12009.2522010.0531957.01
Thanks,
Pete
Forum|alt.badge.img+54
  • Sep 12, 2016 5:01 PM UTC
A point on area overlayer followed by a list exploder should work here
  • Sep 12, 2016 5:23 PM UTC
@egomm It still is not working for me...Could you provide a stub/example of how you would set this up?
Thanks and sorry if I'm making a rookie mistake,
Pete
  • Sep 12, 2016 9:40 PM UTC
Just a little elaboration on the above recommendation by @egomm
In the PointOnAreaOverlapper Parameters:
I selected the 'Only Use Incoming' Accumulation mode
Checked the GenerateList box and assigned a list name.
For some reason, when I performed a tester to reduce the number of polygons, I received a lot of ListExploder <rejected> hits. When I didn't filter the areas then I was able to achieve the proper results (still investigatint why I didn't get the corresponding subset of polygons...)
Thanks to SAFE to working this through with me!
