Every time a create a dataset in fme in the coordinate system EPSG:25832 and try to read it in ESRI ArcGIS, the coordinate is not recognised because FME gives it the name "NUTM32". The parameters are all correct but the name is not known. How can I copy the NUTM32 Coordinate system parameters in FME but just change the name? Then I could easily integrate FME into my GIS workflow.
How can I change the name of name of the EPSG:25832 coordinate system from NUTM32 to ETRS_1989_UTM_Zone_32N?
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
