how can i change incoming data from - to _
  • Apr 22, 2020 7:32 PM UTC
  • 90 views
curtisd54
Forum|alt.badge.img+5
I am looking to change the RouteName column (incoming website data) from - to _ format using FME workbench 2019 2.3.1 . What transformer would complete this task? would StringFormatter work?
chrisatsafe
Hi @curtisshane,
The StringReplacer should do the trick! You should be able to use either mode (Replace Text or Regex) to accomplish this.
