How can I avoid creating "wrong"handed curves with the GeometryReplacer?
  • May 25, 2018 7:26 PM UTC
  • 68 views
I am using the GeometryReplacer with the "OGC Well Known Text" Geometry Encoding. The Geometry Source is "CIRCULARSTRING(@Value(StartX) @Value(StartY),@Value(MidX) @Value(MidY),@Value(EndX) @Value(EndY))". It nicely creates curves from the StartXY, MidXY and EndXY coordinates. But 5% of the curves show the remainder of the curve, not the curve as it is defined by the input coordinates. What is the reason?
  • May 26, 2018 12:03 AM UTC
Could you please post some OGC WKT examples that have been replaced with wrong curves by the GeometryReplacer?
  • May 28, 2018 2:41 AM UTC
I investigated the issue further and discovered that the input data had an minute almost invisible error. I appreciate your interest. But everything is fine with the CIRCULARSTRING command. Thanks so much,
Gido
