How can I alphabetize a text string?
  • Apr 15, 2021 1:07 AM UTC
  • 58 views
I need to check a match between two output fields. The order of the data is inconsistent, and therefore ABC is not flagging as a match with CBA. I want to alphabetize the text strings so that the order is consistent and can be picked up via the equals or contains function in TestFilter.
caracadrian
Forum|alt.badge.img+23
  • Apr 15, 2021 4:36 AM UTC
Sort the characters.
Use StringSearcher with the RegularExpression (.{1,1}) and set a name for the Subexpression Matches List. Use a ListSorter on thatlist{}.part followed by a ListConcatenator on thatlist{}.part and a blank Separator Character.
I have attached a demo workspace that does that for you.
