How can I add attributes without dropping the feature\\table
  • September 7, 2017
  • 81 views
canerakin
I am using FeatureMerger, I want to join the feature class with an excel sheet. Is there any way to add the attributes of the excel sheet to feature class without dropping?
Best answer by erik_jan
I believe the answer is the same as in this question, earlier today:
https://knowledge.safe.com/questions/52496/adding-a-new-field-to-an-existing-feature-class.html
erik_jan
Forum|alt.badge.img+26
  • September 7, 2017
canerakin
  • September 7, 2017
:) Yes I tried it, didn`t work. I can not choose drop, cause there are domains and subtypes in the gdb. When I drop the table, I lose them. I found these articles below, I will try them:
https://knowledge.safe.com/articles/29911/adding-fields-to-an-existing-feature-class-with-fm.html
https://knowledge.safe.com/articles/47216/using-arcpy-for-fme-feature-processing.html
erik_jan
  • September 7, 2017
In that case you should add the fields in ArcGIS and use the Writers > Update Feature Types menu to update the definition in FME.
