How can "Dissolver" create overlaps?
  • Feb 25, 2023 8:59 AM UTC
  • 76 views
I have a non-overlapping dataset of polygons. I change some attribute values around and dissolve on one of those attributes. Now my dataset has overlaps.
Dissolver is on automatic accuracy. Changing this value manually did not change it for the better.
The resulting overlap is small (approx. 1mm width), the dataset is only in the scale of several 100 meters though. So this is not some sliver in the nanometer range.
How does this even happen, and how can I avoid it?
workbench
DanAtSafe
Forum|alt.badge.img+23
  • Feb 27, 2023 5:17 AM UTC
Hi @riverag​  Which build of FME are you using? If it's 2022.2 or 2023.0, please submit a case here - https://community.safe.com/s/submit-case Thanks!
  • Feb 27, 2023 6:35 AM UTC
I should have mentioned it's FME 2021.1. I might upgrade if this is a version issue.
DanAtSafe
  • Feb 27, 2023 4:28 PM UTC
You'll have to upgrade first to find out if it's been fixed or not - or just submit a repro package when filing a case.
@riverag​ Just a reminder that you can have multiple versions of FME Desktop installed - just use a different install folder while you're testing.
