How can a write an attribute from the first feature to every other feature?
  • Jul 16, 2018 2:21 PM UTC
  • 6 replies
  • 215 views
I have gps points, each with a creation_time attribute. I would like calculate the elapsed time for each point using the creation_time of the first point as the start_time.
My thoughts are to write the start_time to each feature and use DateTimeCalculator.
Any ideas how I can select the creation_time from feature 1 and write it to all other features as start_time?
If there is a better, I would love to here it.
regards
Martin
  • Jul 16, 2018 2:49 PM UTC
Hi @martino51, I think this is a case where a global variable can be used effectively.
gio
Forum|alt.badge.img+15
  • Jul 16, 2018 3:19 PM UTC
@martino51
Variable setter/retriever is usually my preffred one too but..one has to hope the retriever does not pre-empt the setter..wich often makes me revert to simply
unconditionally feature merging the sampled value to the non sampled. ( sampler and a FeatureMerger)
Hi @martino51
you could also use Adjacent Features in AttributeCreator. Combined with Conditional Value, this functionality will allow you to pass the first point start_time onto all other points:
As a matter of fact, you could also calculate the time difference using @DateTimeDiff() function in your expression.
tpistor
Participant
  • Participant
  • Jul 16, 2018 11:01 PM UTC
Hi @martino51
try, complete and modify
attached workbench
gps-elapsed-time-from-first-point-2-all-other-poin.fmwgps-elapsed-time-from-first-point-2-all-other-poin.png
  • Jul 17, 2018 1:01 PM UTC
Thank you to all for your suggestions. I used @takashi's and @gio's suggestions of a global variable using the VariableSetter and VariableRetriever. This is what I was looking for but didn't know how to do it in FME. Many thanks to the FME community for your support.
  • Jul 17, 2018 1:45 PM UTC
Good to hear.
I found another solution. The StatisticsCalculater can also be used to calculate elapsed time (seconds) since the first point.
Expression for calculating time interval (seconds) between two adjacent records (assuming that "creation_t" is formatted with standard FME date/time format)
@DateTimeDiff(@Value(creation_t),@Value(feature[-1].creation_t),seconds)
