Highest score overall
  • Oct 6, 2020 2:10 PM UTC
  • 5 replies
  • 77 views
jan_van_prooije
Hi, i have a question which i think should be solvable with fme but i don't know the right transformer(s) to get the solution.
Maxithlon
I have this table with points and id's. I would like to know the best way to calculate the highest score (1+2+3) but without using one id twice.
Do you have any id how to solve this?
Some extra info:
Maxithlon 2
Calculation 1 is not valid, here the sheet pics just the highest values (but picks A twice (not allowed)
Calculation 2 Here it picks the value of A (10) because it is the highest value in the table, but overall it is not the highest accumulation of points.
Calculation 3 is what i am looking for, Here it picks the value's which calculates the heighest overall points for the table
Jan
Best answer by ebygomm
It's not actually something that's easily solvable in FME in my opinion
You could use an inlinequerier to create all possible permutations then add up the scores and sort and keep the highest. If you have lots of data then python is probably going to be a better option
Capture
danilo_fme
Forum|alt.badge.img+58
  • Oct 6, 2020 2:25 PM UTC
Hi @jan_van_prooije​
Did you try to use the transformer StatisticCalculator?
Thanks in Advance,
Danilo
jan_van_prooije
Thanks in Advance,
Danilo
Thanks for the advice! i tried to use it, but i'm not getting the results i want. (added some more info in the question).
jonas_nelson
Forum|alt.badge.img+34
Perhaps https://hub.safe.com/publishers/pacific-spatial-solutions/transformers/listsubsetenumerator could help solving this?
(I'm not sure exactly HOW though).
Forum|alt.badge.img+54
  • Oct 7, 2020 3:10 PM UTC
Capture
jan_van_prooije
Capture
Thanks a lot! The InlineQuerier, didn't know that transformer😅
