hidden attributes SQLCreator
  • January 11, 2017
  • 6 replies
  • 86 views
boubcher
Forum|alt.badge.img+11
Is there a way to expose the hidden attribute when we use the SQLCreator but the table name is entered as published parameter, ( select * from dbo.[$(table_name)] )
the inspector is showing only one column, with no list of all the attributes
Best answer by erik_jan
The SQLCreator has a field to enter the attributes that need to be exposed.
You can enter them by typing the names of the attributes.
See image below:
erik_jan
Forum|alt.badge.img+26
  • January 11, 2017
See image below:
boubcher
  • January 12, 2017
I know , but the problem is we don t now the attributes name , since the table name is set as published parameter and it will be giving only when we run the worksapce , and we have a loot of tables
nielsgerrits
Forum|alt.badge.img+64
@boubcher It's not clear to me what you need exactly but there is a reason why you can't auto expose attributes: Transformers can often not be configured for unknown attributes. If you want to dynamic translate data the FeatureReader and FeatureWriter do all the magic in my opinion. It took me a while to get used to this way of thinking but I don't know how I ever could do without these.
boubcher
  • January 13, 2017
but how do you pass the Table name you want to read from the DataBase in order to get all features,
nielsgerrits
The same way you do when using the SQLCreator. As attribute or parameter input in the field FeatureTypeToRead.
fmelizard
Forum|alt.badge.img+21
  • January 15, 2017
We should ask what the reason is that you want the attributes exposed. Do you want to have them written automatically to an output format? Then the instructions RE: Dynamic schema and FeatureReader make sense. Do you want to use the attributes further downstream as parameters to other transformers? That can work but only if all tables you'd ever plan to use have the attributes in question. If you just want to inspect them in the data inspector, FME 2017 has a "Columns" button that will allow you to see them there.
