Hi, when using ImageRasterizer transformer, is it possible to fill the empty spaces with color in order to get a continuous, solid look?
  • Aug 19, 2020 9:25 AM UTC
  • 37 views
I'm successfully using the ImageRasterizer transformer to create images of extracted parts of a 3D model. The result is a png with a "wired optic" (see attachment).
Is it possible to fill the empty spaces with color in order to get a continuous, solid colored surface? Without having any empty spaces like I'm achieving now?
Many thanks for your help 😃
Regards,
vill
itsmatt
Forum|alt.badge.img+48
  • Aug 19, 2020 10:20 AM UTC
You can possibly try the MapnikRasteriser instead. That has a bit more control over how the features are represented.
