Hi Team, I am fairly new to FME. I am trying to find and export the maximum value across a few attributes. Please see example below.
  • Nov 7, 2022 4:01 AM UTC
  • 123 views
calvin.fme
Example
Name | Try 1 | Try 2 | Try 3 | Try 4|
Tom| 3  |  6  |  0  |  2 |
Bob | 2  |  7  |  1  |  6 |
Kat | 1  |  8  |  1  |  3 |
Export
Name | Try | Highest Score
Tom | Try 2 | 6
Bob  | Try 3 | 7
Kat  | Try 2 | 8
Much appreciated
Best answer by ctredinnick
Learn the example above first, but..
The uglier, less dynamic way to do this is with the @max() function, which takes the largest value of its inputs. And a conditional to identify which attribute it was which matched.
cory
Forum|alt.badge.img+7
  • Nov 7, 2022 5:30 AM UTC
Hi Calvin,
One way you could do this is;
Basically, split each Try 1,2,3,4 into a separate row. Do this by creating a common attribute (i.e. Value) and comma separate the values (AttributeCreator):
imageSplit that column using the AttributeSplitter, splitting based upon Comma. This will create a list, that you will need to explode (using ListExploder)
imageThe new value _list is created. Just use AttributePivoter to group the rows by the Name and analyze the _list attribute and create the summary as Max.
imageAfter the Data output from AttributePivoter, you can use the AttributeRemover transformer to clean up any attributes that you don't want to keep.
ctredinnick
Forum|alt.badge.img+22
  • Nov 7, 2022 7:27 AM UTC
f.kemminje
Forum|alt.badge.img+11
  • Nov 7, 2022 3:21 PM UTC
here is w bench
calvin.fme
  • Nov 8, 2022 2:57 AM UTC
Thanks for the assistance guys. All the methods worked!
