Hi, I would like to test the condition if with the @stringlength function. Test condition: If the length of the "section" attribut is equal to 2 then keep the attribute value. If not add ‘0’ before the attribute value. My query doesnt work.
  • December 13, 2022
  • 13 replies
  • 101 views
Can you help me to find the solution?
Thanks,
Best answer by stefanh
You don't need the @Evaluate part in the Test.
This works
tomfriedl
Forum|alt.badge.img+13
  • December 13, 2022
Without Test-condition:
Transformer StringFormatter, Format String: 02s
  • December 13, 2022
I use the "AttributeManager" transformer with Test-condition.
stefanh
Forum|alt.badge.img+8
  • December 13, 2022
In this case the StringPadder - Transformer might also be the solution.
  • December 13, 2022
Capture
  • December 13, 2022
Need to add a new transformer ? Not possible to do with AttributeManager and Test-condition ?
stefanh
  • December 13, 2022
This looks good. Is it working?
There is also the @PadLeft StringFunction you can use in the AttributeManager.
tomfriedl
  • December 13, 2022
I think FME is confusing the brackets in the attribute identifiers.
your condition is
@StringLength(@Value(Section (R ...))) 2 = @Value( ...
What does the 2 (at this position) stand for?
  • December 13, 2022
Not this position.
The 2 means 2 characters
tomfriedl
  • December 13, 2022
Test conditon: @StringLength(@Value(test))=1
Value: 0@Value(test)
else do nothing.
  • December 13, 2022
else do nothing.
non change
tomfriedl
  • December 13, 2022
This works:
StringLengthMaybe you can share your workbench/data?
stefanh
  • December 13, 2022
This works
  • December 13, 2022
This works
thank you i understand
